Question about Bosch WFLI 2440 Front Load Washer
The drum has stopped turning so won't wash or spin.
  • Bosch Master
  • 3,463 Answers
Remove the motor and check the brushes, if they are less than 3 or 4mm long, replace them.
Posted on Oct 17, 2010
6ya staff
SOURCE:
Why does whillpool washing machine not want to spin
Is it a top loader? If so, the drum may be out of balance re-arrange the load so that it is about even all the way around and try again. or ..
Troubleshooting Washing Machine That Won Spin DoItYourself com
Why Won the Whirlpool Washer Spin or Drain
Jul 23, 2018 | Washing Machines
The drum in my washer will not rotate. Are they belt or direct drive?
Every washer I have dealt with have all been direct driven through a transmission. There are several reasons that a washer drum will not rotate. The simplest reason is that the door interlock is not functioning properly.
Aug 05, 2016 | Washing Machines
The clutch is super hard to turn. Is this why my machine won't spin?
if the clutch is locked ... or tight... then the drum would be more likely to not STOP turning...
If the clutch were loose then the drum would not engage with the motor...what brand , make model serial number?
Apr 17, 2013 | Washing Machines
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Samsung Washing Machines
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Bosch WFLI 2440 Front Load Washer Logo
64 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
