Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
SOURCE: rs21/fcns fridge freezer fridge keeps
suspect a bad defrost element and defrost thermostat. but if your handy with a volt meter, check out the defrost heater with the "beeping" option if good,if it doesn't beep, bad defrost element.replace element and defrost thermostat. one step less. second, try to locate the timer, sometimes the timer just gets stuck in cooling cycle and won't defrost. if it's an adaptive defrost board, suspect it faulty. if its an mechanical timer it has a small wheel ,try to turn it if you can't turn it, well there's your problem. your third piece to suspect is the thermostat but I'd change it if the unit never shuts off but i recommend to change the timer first, with defrost thermostat just for safety.
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
SOURCE: the fridge part of my fridge freezer keeps freezing everything,
I tried solution 1 without success, so I resorted to switching the whole unit off at night and on in the day to stop it freezing up. After about a week of doing this it started working properly again. One month later it is still OK
