SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Hi, Here is a tip that may help you with your problem....
I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer... The process for your camera may not be exactly the same, but should be similar.
Move the internal pictures to your card and then switch it to record to the card...
You have to connect to a pc, transfer the pictures to the computer, then you can transfer them from the computer to the memory card file on the camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
The very first thing to do is you have the lumix driver in your computer. Then use the firewire to paired them. Some brands of digital camera give you difficulties to transfer data from mass memory ( camera memory and is not additional memory <mmc/sd>) to other media like computer. It is invisible when trying to import and all you can do is just enjoy the data / pictures by using play back features in your digital camera.
So what you should do is just connect them as usual ( remove the memory card before commence this task) and seek the pictures you are looking for in digital camera. If nothing found there, you can not get the pictures imported then.
Regards, Jay
This should help
Press [ menu set] to display the [PLAY] mode
menu and select the item to set.
You can copy recorded picture data from
the built-in memory to a card or vice versa.
1 Press up/down to select the copy
destination: (in to card) and then press
[MENU/SET].
