run a cycle of blech and hot water through the system 3 times and it will rinse away all the mildue (build up) in the barrel and pipes to stop this from happening use a liquid detergent and try not to use fabric softner
Hi Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Please post back for further assistance. Hope this helps... Daniel
The moldy smell is really common with this machine, and maybe all of them, but I have the LG TROMM and was ready to throw away all of my towels. Here's a solution I found that helped alot. First, Clorox makes a solution just for front-end loading machines. You run it through on a cycle with no clothes, that helps to clean it out.
I ran my towels through on the cotton/towel cycle on HOT, with nothing more than white vinegar filling the detergent dispenser. After that, I then ran them through again with just a bit of soap and fabric softener. They came out soft and smelling like new.
I read recently that we all use WAY too much soap in both our washers and dishwashers, even though that's what's recommended in the directions. Excess soap in clothes that doesn't get rinsed out will begin to smell moldy. So I now use about 1/4 of what the directions call for, and they come out fine. I have found, however, that I need to repeat the vinegar cycle once every few months. I think the problem is inherent in that model machine.
And that rubber seal? Disgusting! I clean it out regularly, but when it's full of water after every load of clothes, what do they think is going to happen??? You'll find that Clorox cycle will clean the seal pretty well, though. Good luck!
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use
powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door
open to allow it to dry. .
Pull the rubber door seal back and clean the mold off . Affresh is recommended by some manufacturers. You run it through
a wash cycle with it.
That happened to me too. Check for mold and mildue around the inside seal, if you find anything BLACK, clean it up. Also, pull out the drawer where the laundry detr is and clean it as well. Also, when the washer is not in use keep the door open, this will cut down on the mold and mildue.
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
