Watches Logo
Posted on Oct 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have replaced the battery in my Indiglo watch, however, I can not get the back cover back on the watch. Do I need to take it to a jeweler to get it back on or what?
Janelle Schoonover
Level 3:
  • Master 842 Answers
  • Posted on Oct 08, 2010
Janelle Schoonover
Master
Level 3:
Answers
842
Questions
Helped
457611
Points
2634
Thank you for contacting FixYa.
Yes,, you can take to a local jeweler. They should have a watch press to press the back on.
Best regards. Jewel
My Timex ironman won't beep and the indiglo won't work.
IndiGlo uses a separate battery as the watch has two. Take it to a local jeweler and have both batteries replaced.
My timex won't beep and the Indiglo doesn't work.
Question moved from Cars and Trucks.
https://www.fixya.com/support/r27181038-changing_watch_batteries
2answers
6helpful
2answers
I have a ladies timex indiglo watch that I was able to get the back off and replace the battery but now I can NOT get the back on again. It doesnt seem to have any grooves on it. It seems as if it would...
I have an old Timberland Indiglo watch in which I had the same problem. I folded up a paper towel for padding and I used two sets of pliers, one to hold one side of the watch while I used the other set of pliers to snap the back cover closed. It took two seconds to do.
Have opened Timex Indiglo watch and replaced the battery. However, I can not repace the metal back on the watch. Is there a trick?
Was it a back that you "pop" off with a small screw driver or other? It should "pop" back on but push with your thumbs on the outer side of the back, or you may have warped the back by pushing too far in the center of the back. You may need to take to a jeweler who has a watch press.
Sorry, but this is the risk you take when doing on your own without the right equipment.
Aug 22, 2010 • Watches
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
10helpful
Can't put (back) back on my timex indiglo
I used to work with jewelry. !!BEWARE!!
This method is for face crystals that are completely FLAT! Any convex crystal will shatter without proper tools!!!
Any method of putting the watch cover back with the watch remotely near water/moisture is a mistake. The watch will rust sooner or later.
So if you don't want to pay a jeweler five dollars to put it back on, this is what I did to my sister's watch cover when I could not snap it back.
I took my cushy 1/4 inch mousepad to a vise. You may not have a vise. If you don't, stop reading now and take the watch to a jeweler --one who replaces batteries.
Inside the vise jaws, I used a 5 inch square piece of wood, then my cushy mousepad, then the watch facing the pad, then the back in the right place for restoring.
!!!!NOTE: Not having the back in the right place will smash the stem and damage can/will result!!!
To push the back on, I picked a 12 point socket out of my socket set that was the same DIAMETER as the watch back and placed it CENTERED behind the back.
Recapping, inside vise:
  • small board
  • cushy mousepad (to avoid scarring and crystal breakage
  • watch crystal facing mousepad
  • watch back in correct position
  • ratchet socket the same diameter as watch back centered behind cover
Slowly I positioned all these items with minimal pressure. Then when I was sure that I was ready (and prepared to hear the crystal break) I put as little pressure closing the vise that I could. The I heard a snap, and to my relief, it was the back going in!
I DO NOT RECOMMEND THAT YOU DO WHAT I DID. People with broken watch crystals become very IRATE when "all it needed was a battery"!
A screw clamp would also give adequate pressure. Any unsupported direct pressure over the crystal will shatter it!
Hope this helped.
Good luck!!!!
5helpful
4answers
Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
