Question about Blenders
Cuisinart bc56 blender
How do i change the clutch on this blender i have brought a new clutch but can't get the old one off!help I need to replace the clutch on the blender and I don't know how to remove the old one and replace with new one.
  • Anonymous Oct 19, 2008
    I am usually quite handy with any widgets and gadgetts but this one is a real pain in the patunski and I will probably never buy another Queezy art product again! I cannot, for the life of me, get the old driver clutch off of the working end of the motor shaft and need to do this first, before I can even begin to install the new one.The motor will not come out of the blender housing until the clutch is removed and there is no apparent set screw on the actual clutch driver plate itself. There is only a flat head screw located at the other end of the motor shaft which acts as if it was welded into place! Please help, if someone out there in magic box land has the answer, I'd sure appreciate hearing it. Thanks! wwmarkush
  • Anonymous Jan 19, 2009
    How do you remove the clutch - there are so many websites selling the clutches - but with no instructions on how to replace them! It madness!
Instructions found in operations manual. "The rubber clutch disc on the blender base has reverse threads. To replace , remove the rubberclutch disc by threading it clockwise. To install the new clutch disc, thread it onto the motor
shaft counterclockwise."
Posted on May 19, 2009
Huh?
Posted on Jun 07, 2008
Anonymous
SOURCE: cuisinart bc56 blender
I cannot find the part of the rotator that goes on the blender. the cuisinart parts only have the one that goes into the jar
Posted on May 11, 2008
Where can I buy a clutch for a vita mix 5000
Shop for buy a clutch for a vitamix... on Google
Amazon.com: Vitamix Drive Socket Kit: Electric Countertop ...
www.amazon.com/Vitamix-891.../B0028Y4CVE
Amazon.com, Inc.
Rating: 4.7 - ‎249 reviews
Shop Vitamix at the Amazon Small Appliance Parts & Accessories store. ... blender on the fritz, PLEASE do yourself a favor and check the old drive socket before buying a whole new blender. .... This fitted perfectly into my vitamix super 5000.
Vita-Mix Parts: OEM Replacement Parts ' Parts Town
Dec 03, 2015 | Vitamix Vita Mix 891 - 1-Drive Socket Kit...
Kitchenaide blender pitcher blade assembly sticks
You need to lock the blades from turning and undo the bottom clutch drive in such a way as you do not damage it. I use an old motor clutch drive to undo them myself. It has a left hand thread and a block of wood to hold the blade. Then you can remove the blade with shaft from the brass bush to clean and lubricate it. If the brass bush has moved up in the plastic housing you need to press/bang it down again. Then reassemble. If you wreck the clutch drive on the blade you will need to buy a new blade assy if it is separate to the beaker, if not you will need a beaker and blade unit complete.
Jun 23, 2014 | KitchenAid KSB560 5 Speed Blender
How to change clutch in Hamilton Beach blenders
You need a screwdriver and soft hummer. Secure the screwdriver on one teeth of the cluch and lower the screwdriver to have un angle of around 60 degrees. Now you hit a little fast the scredriver with the hummer in order to unlock and unscrew the clutch. Then it will be easy to unscrew with your fingers. This is a litle bit triky so you may need to try some times in order achieve it.
Please remeber that you it unscrew reverse than it rotates.
The new one need only to screw in place and it will lock by itself as soon as you will use the blender.
Good Luck
Aug 02, 2010 | Hamilton Beach 908 Commercial Work Top...
My cuisinart spb-7 blender won't spin
How do I replace the blender blade driver clutch? I have the part but do not know how to get it in.
Jun 13, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Kitchen Aid Blender - blade not rotating
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Also check the clutch blade on the jug itself.
Apr 01, 2009 | KitchenAid Blenders
How do I change to clutch on this blender. The outside of the clutch broke off leaving just the screw head on the blender, when I turn to unscrew it, the entire piece just spins, any suggestions.
You can probably use a Vise-grip pliers to clamp down on the brass insert and unscrew it. Not only is it on very hard, but it is also threaded reverse of a normal screw. This is so it does not come undone in normal operation.
You have to turn it counter-clockwise to unscrew it (a regular screw turns clockwise).
I had to clamp the motor shaft real tight with a bench vise to be able to remove the clutch. Hope this helps.
-Vince
Aug 14, 2008 | Cuisinart SPB-7 SmartPower Work Top...
how to get the base off the glass container. turn in what directionss it seems stuck
Feb 27, 2008 | Cuisinart CBT-500 SmartPower Premier Work...
VILLA WARE 5767
my blender jar is broken. I need to replace it
Aug 05, 2007 | VillaWare 5787 Double Smoothee Work Top...
Replace clutch assembly Waring BB150 Blender
Remove the little rubber feed on the bottom of the base (they might be glued a bit so be careful not to rip them). This will reveal 4 phillips head screws...remove them...this will open the base and reveal the back site of the rotor. In the middle you will see a turban blade like wheel with a large flat tip screw. Wedge a large screwdriver between the teeth of the old clutch so that when you turn the flat tip screw it will stop rotating the other end. Turn the screw with some force to the right to losen the clutch...then do the reverse to get the new one on tight...put everything back together and there you have it.
Keep in mind that this might void your warrenty if you still have some on it.
Apr 13, 2007 | Waring BB150 Work Top Blender
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Blenders Logo
422 people viewed this question
Top Blenders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
