Kenmore 43142 Front Load Washer Logo
Posted on Nov 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black marks on clothing
Did you solve the problem with the black marks on your clothing? I am having the same problem and also had to clean out the tray for around the softener container. After cleaning the black stuff out of the tray and running a "clean" cycle, I'm still getting black marks...look like grease...on the clothing.
Scott
  • 5 more comments
  • Anonymous Jun 29, 2008
    The problem is the bearing seal on the drum has failed and now the water is pickning up the grreas that is being spun out of the bearing. I know because mine is now apart on the garage floor. Bythe way the arms holding the drum will break apart and the parts are not available seperately. I hate this thing.
  • Anonymous Jul 11, 2008
    Same problem here - black marks on clothes and noisier spin cycle. Sears repair guy gives us a $600 estimate to replace tub bearing. I've had cheap used washers last longer than this pile of junk. Very disappointed in Kenmore/Frigidaire. Anybody have advice on good washer to buy?
  • rayna1022 Jul 27, 2008
    I am finding gray/black lines/streaks on my clothes - it shows up especially on white clothes.
  • lordan07 Aug 10, 2008
    I am havin gthe same issue black marks , not able to get them out of the cloths and now have ruined hundreds of dollars of clothing , what the heck is the issue , I cant find any black grease or oil on the drum , removed the back and cleaned the drain line , very black water removed but dont think that is the issue that was probaly the mildew or smell that ihave been experiencing also
  • mcmurphy18 Sep 04, 2008
    No matter what detergent I use, clothes frequently come out with spots that weren't there when I put them in.
    I've cleaned the drum, dispensers, and the rubber gasket.  I've also tried extra rinses, HE.  They're not coming from the dryer because I haven't used it all summer.
  • Anonymous Apr 09, 2009
    black marks on white clothes only.......some blobs, but mostly lines, curved lines.........kenmore stacking washer and gas dryer
  • ecclesmd May 11, 2010
    Check the seals, if your water heater is set too high, you can melt the rubber seals.
Chris Huff
Level 3:
Top Expert:
  • Kenmore Master 6,289 Answers
  • Posted on Nov 03, 2017
Chris Huff
Kenmore Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2019878
Points
74913
Sounds like grease or oil from transmission may be leaking and finding its way into tub.
2 Related Answers
Anonymous
  • Posted on May 28, 2008
SOURCE: Black marks on clothing
I have had this problem with my front load washer and have been able to solve it by cleaning the buildup off of the lower part of the glass window on the door.
Ian Jones
  • 77 Answers
  • Posted on Feb 10, 2009
hi, i think you will find the bearing on the drum is about to fail, you need to replace it, hope this helps
Black marks on clothes
Possible that the machine needs a good clean up and so it is best to use the right cleaning method.
please check this link : cleaning washing machine
2answers
My washer leaves black marks on my clothes. I do not use fabric softners
Do you mean Black, really black marks? Perhaps dark brown.
Some marks comes from moldy seals, other marks comes from leaking gears from the machine. Examine the marks, check if those marks are oily or not.
How to clean black marks left in dryer from shoes
I had used a little nail polish remover on the marks when this happen. Then I wiped it out with a cloth after I was through doing the dishes ( had dish detergent on it) and a rinse cloth and dried. I then always let the shoes/boots air dry or you could put them in a pillow case to dry. Good Luck!
(You should have seen the mess I had with a melted blue crayon one day!) Got that out too-but it took me a while.
Black marks on clothes after washing
Try running a few caps of CLR in the washer (without clothes, of course!) Then run a few cycles with no additives. I've heard that powdered lemonade works also. Might be safer to try first. Good Luck!
1helpful
2answers
Ricoh Aficio AP3800C Printing Problem
If the marks are along the same line and look like dots the black photoconductor needs to be repalced.
Black marks
throw a clean pair of old sneakers in the dryer with the clothes. this should not allow the clothes to stay in one place during the entire dry cycle
Alexander
vince
