Just found this on the internet not sure if it will work for you but have a read up about it.
Rundll problem issues are caused by misconfigured system files. Rundll problem usually happen when the computer's registry system overloads with to much data, or when certain system files become missing or broken.
The Rundll problem issues are easy to repair. By downloading and running the registry repair tool System Optimizer, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your download.
Download & Install System Optimizer.
Note:If the download link doesn't work you may need to Download it from a mirror
Click the "Quick Scan" button.
Click the 'Repair All' Button to Repair Your PC.
SOURCE: after starting the laptop. it won't do anything
Hi..
In that case your laptop is already infected by the virus, came from your mp3, and it's also display the dll, you need to reformat your laptop the causes of that problem is the virus which is blocking the files you want to execute.
Good luck !!!
Regards
PCmania
SOURCE: Every time i start my hp laptop running windows 7
hi,
This may because you might have unknownigly deleted this component.When you scan your computer for virus also the antivirus may delete some coponent. To get rid of this please format/reinstall your window 7 operating system. you wont get this problem again.
thanx
SOURCE: Run DLL, there was a problem starting the
This issue is certainly with the OS.. Once you restore the computer to the factory settings it will be fixed
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
SOURCE: When I start up my laptop this message box comes
File dll32.exe is NOT a Windows core file--It is a leftover piece of code from malware.
File dll32.exe is usually located in the folder C:\Windows\System32--delete it
