ASUS NVIDIA nForce Chipset A7N266-VM (A7N266-VM W/L) Motherboard Logo
Posted on May 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ASUS A7N266-VM Mine motherboard isn`t working anymore. I hear no beeps. They say the motherboard has problems on his own. Anyone know the problem?
  • 1 more comment
  • Anonymous Jun 16, 2008
    no voaltage on cpu socket and ic AMS1505CMA is over heat?
  • Wilfred Rex Nov 18, 2008
    I am also having the same problem. When I start the PC no beeb is coming. Only CPU Fan is rotating. Even BIOS is not loading. I am not seeing any POST. I can't enter into SETUP also. Even I removed the RAM then I tested same result.
  • Anonymous May 18, 2009
    I am also having the same problem. When I start the PC no beeb is coming. Only CPU Fan is rotating. Even BIOS is not loading. I am not seeing any POST. Even I removed the RAM then I tested same result.
    I powered down the system if I try to boot again continuous ambulance sounds are out. Donno what to do
Anonymous
Level 2:
  • Expert 121 Answers
  • Posted on May 27, 2008
Anonymous
Expert
Level 2:
Answers
121
Questions
Helped
91566
Points
231
Try to clear (cmos) here is the way:
get to the jumper located near the cmos battery, short it for 3 seconds then return it to its normal position. start the system and load setup defaults.
In my Asus A7N266-VM motherboard there are problem with cemos i replaced the cemos battery but it s not working , forget the time&date and every time i have to press f1 for starting the windows
CHECK ALL CAPACITORS (3300uf - 6.3 volt).
IN MY MOTHERBOARD THEY ARE PLACED IN INCORRECT POSITION (YES....INVERTED!!!).
THIS FACTORY MISTAKE PRODUCES RANDOM RESETS AND COMPLETE FAILURE IN POWER SUPPLY +5 volt rail)...Check the power supply too and see my video:
http://www.youtube.com/watch?v=_eglqjBHNmc&feature=channel_video_title
Asus motherboard( A7N266-VM)
FOr reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defaults.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Motherboard problem
http://support.asus.com/download/download.aspx?SLanguage=en-us
goto the above link and enter your model number into the search and it will tell you to select your os and then it will bring up a bunch of drivers for your board
ASUS Motherboard A7N266-VM
If you have another video card you can try (you can put an AGP card in there, it will disable the onboard video automatically), take that route first. If you can't, or it occurs with another card, it may be your power supply. It would help to know if your pc beeps when you turn it on, and how many - if any - beeps there are.
1helpful
3answers
No sound driver can i get one free
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
