Push the stopper down to fully seal the stopper against the tub drain.
Turn the knob on top of the stopper counterclockwise with your fingers. Do not lift the stopper while turning the knob. Remove the knob from the stopper.
Insert a large flathead screwdriver into the slot on the center shaft of the stopper. You will see the center shaft when you remove the knob. Turn the shaft counterclockwise to unthread it from the retaining hole in the bathtub drain basket.
Use a pair of vise-grip pliers to turn the shaft if the center hole has corrosion and will not accept a screwdriver. Lock the jaws of the pliers securely around the shaft, and turn the shaft counterclockwise.
Pull the stopper out of the tub by lifting it by the shaft.
I don't see the comment. All I see is sdfds, sdfsdf, sdf Where do I go to get a solution
Please let me know how to view a comment
