This information is from repairclinic.com
F/02
Long
Drain
If
the drain time exceeds 8 minutes, the water valves are turned
off and "F/02" is flashed.
NOTE:
After 4 minutes the "Sud" error will be displayed,
then 4 minutes later the F02 error code will be displayed.
Press
PAUSE/CANCEL twice to clear the display.
The drain pump filter is located in the front, center of the machine at the bottom behind the lower panel that can be removed by taking out 3 screws.
I hope this helps. Here we are starting with the most obvious. If not the filter, it could be the pump itself, or the flowmeter, but try this first. Handiest1 10-1-10
Testimonial: "Took off the front panel and saw the drain cap. Had to drain at least 1 gallon of nasty water, lint with shop vac. Cleaned up, all is well. Thanks"
