Sony FD Trinitron WEGA KV-34XBR800 34" TV Logo
Posted on May 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Standby blinks 7 times
Comment by madd4, posted on May 24, 2008 I tried to turn on my Sony FD Trintitron Wega KV-34BR800 34" TV with NO luck. The standby keeps blinking 7 times. Once the Sony FD came back on and was ok until I turned the set off... now it's back to the standby blinking 7 times mode. We called Sony which connected us with a Tech that came out to the house... the bad news it was the D board and that it would cost $559.05. He added this happens all the time. Of Course you know what I think of Sony products now. It's probably smarter to purchase a new TV.
  • madd4 Jun 11, 2008
    Haven’t been on-line… had some trouble with my computer. Today, QU***SERV TECH came out to my home and put in a D-Board. The TV is working now. I told the Tech that my husband wanted the old board but the Tech said he has to take the old D-Board and ship it back to Sony. I ask him why and he said it's like purchasing breaks for an auto - you have to return the part (core) or my company will be charged $150. He insisted on taking the board... I couldn't wrestle him to the floor. I’m sorry I did not get more advise from www.fixya.com. It's weird that I was charged $263.48 for the part and SONY wants the old board back? Total job was $559.05. Thank you!!!
    Thank you for the information that you pervaded regards to my problem! It was greatly appreciated!
Anonymous
Level 2:
  • Expert 80 Answers
  • Posted on May 27, 2008
Anonymous
Expert
Level 2:
Answers
80
Questions
0
Helped
57325
Points
120
The part # for the d board is A-1300-319-A pts corp can rebuild it for about $250 www.ptscorp.com
  • Anonymous Jun 11, 2008
    cores for circuit boards are getting very common - the companty send them back and repair them and resell them - on an other note $150 for the core is little much -
    Core Price
    35.00
    Part Price
    271.90
    Total Price
    306.90
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
492
Points
How reconnect the red and white wire on the D-board?
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on May 26, 2008
Anonymous
Expert
Level 2:
Answers
71
Questions
Helped
20463
Points
105
These 'D' boards can be sent to Sony for repair- cheaper than replacing with new board. Find a reputable Sony repair shop
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
1helpful
The standby botton blink 7 in my sony trinitron
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Sony FD Trinitron WEGA KV-34HS510 34" TV won't turn on. Standby light blinks 7 times
  • Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board). This may help !!
1helpful
Blinks
The blinking standby light should be in a repeating pattern of a fixed count of blinks. Please post that count here as that will indicate the circuit in which a problem was detected. Armed with that info, we can then tell you the problem and probable solution.
Thanks,
Dan
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
15helpful
2answers
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Sony kv-30xbr910 my tv won't turn on and the standby fashes 7 times
Good day.
Your unit has issues with the high voltage section. Particularly the vertical and horizontal sections. Blinking lights indicates that your flyback is not osscilating to distribute the supply to the sections. Please have it checked by a repaiman.
chris
Sony wega model: kv-32FS120 doesn't turn on
Check your power supply board and resolder the pcb, check the switching diodes and zeners.
KV-32FS120
Seven Blinks: High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into shutdown. Check power supply and horizontal circuits.
Culbert Communications
New Brunswick, Canada
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
