The smaller of the (2) lines will go to the in-tank fuel filter/weight. Depending on the model, the line will attach to the filter with about 2.5-3.0 inches of additional fuel line within the fuel tank.
The larger fuel line is the return line and needs to go into the fuel tank about 1/4 inch or so.
You should have both size holes at the bottom of the fuel tank to accommodate. Insure you are using the correct fuel line as a complete seal is necessary due to slight pressurization and to prevent leakage.
