Omega 1000 Juice Extractor Logo
Posted on Sep 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Omega Juicer 1000 shakes violently and the entire machine rotates unless I firmly hold it or turn it off. It's been in the closet for good seven years before I took it out and started using it. It's been in use for around 4 years with no problem before, but this is the first time I've seen the juicer vibrates so much that the whole machine rotates with it. Any suggestions??
Anonymous
Level 2:
Champion:
  • Expert 356 Answers
  • Posted on Feb 02, 2011
Anonymous
Expert
Level 2:
Champion:
Answers
356
Questions
0
Helped
125059
Points
478
Make sure the bottom of the feed chute is not damaged. If it,s chipped or scored, try filing
it down level as best you can. Then with the juicer fully assembled, unlock the set screw
on the center of the bottom and turn it clockwise until the chute contacts the blade, then
back it off a half turn and lock it down. By the way a dull worn blade will produce less
vibration. I'm assuming the lid is plastic.
  • Robert
    Robert Nov 01, 2013
    THE SOLUTION TO VIBRATING. If it spins up ok and starts vibrating suddenly as you are feeling it, here's the solution: feed it very, very, slowly. that's it. i couldnt figure mine out, then realized that if i fed it slowly, it was just fine.
Robert
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 01, 2013
Robert
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3131
Points
THE SOLUTION TO VIBRATING. If it spins up ok, and starts vibrating suddenly as you are feeling it, here's the solution: feed it very, very, slowly. that's it. i couldn't figure mine out, then realized that if i fed it slowly, it was just fine.
5helpful
My omega 1000 juicer won't turn on - I just bought it today.
Make sure it is assembled correctly and the latch arms snap shut completely
without any undue force. Also on the bottom of the juicer there should be a
reset button that might have tripped, just push it in. Other wise give Omega
a call.
After juicing a few carrots[some of which were cut on a slant], or several spinach clusters, the machine seems to get off balance and begins shaking violently and making a racket at which point I have to...
There's nothing wrong. These juicers do not eject the pulp and go out of balance very
easily. If you continue to have problems you may have to go for a different type of juicer.
The Hurom or Omega VRT, expensive, look good if you're really into juicing.
I have an Omega Juicer Model 1000. When I try to juice citrul fruit. The jicer may only turn for a second or two than stops. When I push down on the citrus it oftentimes will not operate.
If you're talking about the citrus attachment, there may be a
problem with the gearing inside. I have one for my Acme
which I don't use because of it's awkwardness and juice
splattering characteristics. Better off with an inexpensive
citrus juicer and leave the Omega to its carrots and apples.
1helpful
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
1helpful
Juicer just stopped working
call or email omega url:omegajuicersdirect.com
3helpful
Need to replace latch arm omega juicer
First thing to do is call Omega and order a pair
at 1 800 633 3461 and also ask them for tips on
how to remove and install the arm. If your juicer
is older the new arms may not be an exact fit, and
you will have to do a little filing and improvising to
install them. Its helpful to remove the 4 screws on
the bottom to separate the base for better access
and view of the situation.
1helpful
HI, I have omega 1000 juicer, and the latch arm was broken. I ordered the replacement latch arm online. I received my order today and there is no intruction how to replace it. I looked in omega 1000 manual...
There are no instructions. Call Omega 1 800 633 33461
for advice. Also new arms on an older juicer may not
be an exact fit so you might have to do a little filing
down on the arm to get it to fit. You can remove the
4 screws on the bottom to separate the base and get
a clearer picture of what you have to do. Basically
you have to pry the base of the arm away and push
up to remove it. If you're not handy you may need
some help cause it gets tricky.
I have an Omega juicer. I need to ajust it because it tremble too much Thank you
THIS IS A NON EJECTION PULP JUICER AND THEY
WILL VIBRATE LIKE MY ACME. BEST FOR HARD
PRODUCE LIKE CARROTS, APPLES, CELERY ETC.
FEED PRODUCE SLOW AND STEADY.
2answers
Right Arm of Omega Juicer Model 1000 broke off
CALL OMEGA 717 561 1105 THEY HAVE
THE LATCH ARMS. CHEAP. ASK THEM FOR
THERE ARE TO WAYS TO REPLACE THEM.
One bracket broke. Tried to glue it with no success.
IF YOU ARE TALKING ABOUT THE LATCH ARM, YOU CAN BUY THEM FROM OMEGA AT
717 561 1105. TRICKY TO REPLACE. I REMOVED THE BOTTOM OF THE MACHINE AND
GAINED ACCESS THAT WAY. ONCE YOU SEE THE LATCH ARM SUPPORT PRY IT AWAY
FROM THE JUICER AND SLIDE IT OUT. CALL OMEGA THERE ARE 2 WAYS TO REPLACE
THE LATCH.
Top Omega Juicers Experts
john h
ADMIN Andrew
ADMIN Andrew
Aron
Are you an Omega Juicer Expert? Answer questions, earn points and help others
