Both my Temp and Lamp lights on my VS PJ551 blink red when the unit is turned on. They blink red on and off at the same time over and over again. The projector appears to be working fine (other than it's a little out of focus). I know that if the Temp indicator lights a steady red, the projector has overheated, but these lights are blinking together on and off.
All you should need to do is go to the menu on the
projector, and find the Filter Timer. Hit the right arrow to select the filter
time, and then hold the rest button on the projector until you are prompted to
confirm the reset. Hit menu to confirm and it should now reset the filter
timer. Now cut the projector off and back on and the lights should stop
blinking. I hope this helps.
I have the same problem, only my projector will not display anything. fans turn on, lights blink, but no image appears.tried pluging in a PC and external monitor and no image anywhere. Even got a new bulb and still nothing. any chance of saving it?
How do you see the menu when the lights blinking red cause the lamp to not come on?
red light was flashing,and no projection onto screen, we got light to stop flashing but still no projection
