12 VOLT CONSTANT
ORANGE (+)
IGNITION SWITCH HARNESS
STARTER
YELLOW(+)
STARTER 2
N/A
IGNITION 1
PINK(+)
IGNITION 2
N/A
IGNITION 3
N/A
ACCESSORY/HEATER BLOWER 1
ORANGE (+)
ACCESSORY/HEATER BLOWER 2
N/A
KEYSENSE
LIGHT GREEN (-) See NOTE *1
PARKING LIGHTS ( - )
N/A
PARKING LIGHTS ( + )
BROWN (+)
@ BCM, PIN B10, GRAY 24-PIN PLUG, See NOTE *2
POWER LOCK
RED/BLACK (TYPE A)
@ BCM, PIN A8, 16-PIN GRAY PLUG, See NOTE *2
POWER UNLOCK
ORANGE/BLACK (TYPE A)
@ BCM, PIN A7, 16-PIN GRAY PLUG, See NOTE *2
LOCK MOTOR WIRE
GRAY (+)
IN DRIVERS DOOR HARNESS
DOOR TRIGGER
See NOTE *3
@ BCM, PINK 24-PIN PLUG, See NOTE *2
8957_VUE_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
DOMELIGHT SUPERVISION
WHITE (-)
@ BCM, PINK 24-PIN PLUG, PIN A1, See NOTE *2
TRUNK RELEASE
N/A
SLIDING POWER DOOR
N/A
HORN
BLACK (-)
@ BCM, PIN B2, PINK 24-PIN PLUG, See NOTE *2
TACH
ANY WIRE NOT PINK or RED
@ IGNITION COIL
WAIT TO START LIGHT
N/A
BRAKE
LIGHT BLUE (+)
@ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM
DISARMS with FACTORY REMOTE ONLY
ANTI-THEFT
YELLOW (+), ORANGE/BLACK (-) and RED/WHITE (Not used)
GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column.
