SOURCE: blows the 15 amp fuse
if you live in a town that has a remote starter installation shop you can just go there and buy a new pinswitch for around 6 dollars i recomend changing the location of it under the hood
and if your red power wire has only 15 amps of protection you should switch it for a 30 amp fuse thats the minimum that is going to be pulled when the unit cranks the starter wire so the 15 will deffinately melt or blow and check to insure the ground is perfectly connected (in the world of current vs. resistance the weakest point will give in first...
SOURCE: Remote Start will not start
You need a transponder bypas module as the key has a chip in it. Your choicfes are getting a "hide a key" box and putting an extra key in it then wire as stated in the instructions OR, get a hard wire piece that doesn't require a key but needs 2 keys to program.
Was thatn a mouthfull?? Without that it won't start. To verify this, stick a key in the ignition WITHOUT turning it on. Now try remote start and it will stay running. Let me know if you wantpart numbers. I can also e-mail people with te entire vehicles wire coors and location!!
Peace,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: car won't start, makes clicking sound
If you have a bulldog remote start, you should have it removed right away. I work at best buy, and we will not install these any more because of the problems they cause. You should buy something made by DEI, they cost a little more, but are very well made and come with a lifetime warrenty.
SOURCE: installing a remote starter on a mitsubishi raider 2007
Pull out the fastener pins with needle-nose pliers to remove the heat cover underneath the driver's side dashboard.
Hi harrisongill, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Do you have hook-up instructions that came with the new unit? Or at least the name & model nr?
