Question about Kenmore Elite 45986 Front Load Washer
F 13 code
We have a machine at an apartment building for Housekeeping.
It started flashing the F 13 code last week. Please help as soon as possible as this machine is used by the kitchen crew as well as housekeeping on a daily basis
    New Friend:
Followed instruction to check mechanical linkage and spring was on. Then set machine to diagnosis mode and it seems to start, let some water in but then the armature started moving through the different cycle but nothing else happened. It just kept cycling through the options over and over until it went back to the f13 error
Posted on Oct 03, 2016
    President:
  • 1,314 Answers
Dispenser Circuit Error
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control
Unit (CCU)
• Check Dispenser Motor
if you take the top off the washer you will find a tech sheet in there taped to the side of the washer that will tell you how to trouble shoot the dispenser
Posted on May 22, 2008
  • 5,911 Answers
"F13" is a "Dispenser Circuit Error". If the dispenser motor cannot move to its correct position, the error code is generated. You will need to check the following:
- Check the mechanical linkage from the dispenser motor to the top of the dispenser. NOTE: 9 times out of 10 the small spring that connects the motor to the armature comes off and needs to be reconnected.
- Check the electrical connections from the Central Control Unit (CCU) and the dispenser motor. NOTE: The CCU is the Main Computer located directly behind the wash tub.
- Check to make sure the dispenser motor is running.
In order to see all of this you will need to remove the top panel of the washer. Remove the three screws holding the top panel in place in the rear. Once the screws are removed, the panel slides back then off. Locate the dispenser. Make sure there is a small spring attached from the dispenser motor to a small plastic armature on top of the dispenser. Without it the dispenser will not function. Place the washer in diagnostics mode by performing the following:
Select DRAIN/SPIN, NO SPIN and press any key under OPTIONS (must be the same key) 4 times. "C00" will be displayed on the console as the washer enters a series of diagnostics tests. The first portion of diagnostics tests the operation of the dispenser. You should see the armature moving as the different compartments of the dispenser are being tested. If not, I would suspect a possible dispenser motor failure. As a long shot, the CCU can also fail, but may cause different symptoms and multiple error codes. Press PAUSE/CANCEL twice to exit diagnostics.
I hope this information is helpful to you. Please post back if you need further assistance.
  • Jeff Rockwell
    Jeff Rockwell May 23, 2008
    CORRECTION: I don't believe your dispenser has a spring. You may only have a plastic actuator cam. With the washer top removed, follow the same procedures I posted previously by placing the washer in diagnostics mode. Watch the cam to see if the dispenser moves. If it doesn't, double check the electrical connections. Following the connector leads from the motor to the CCU, you unplug the connector and perform a resistance check.
    The readings across test points 6 & 5 (the left pair of wires) should read 0 ohms - Dispenser Switch.
    The readings across test points 1 & 3 (the right pair of wires) should read 1400 ohms - Dispenser Motor.
6ya staff
SOURCE:
The engine light is flashing what does it mean
get the codes first the car will say what is wrong .then come back on here after you get the codes.
Dec 18, 2012 | 2003 Renault Clio
I've had the same fault 3 times now in the last 3 weeks."Door" flashing fault.Firstly,the engineer replaced the door lock. Fault occurred again a week later,so he replaced PCB board,but fault...
I need some more information to the brand and model number to assist you. Please get back to me and I will help you the best way possible.
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 09, 2011 | Washing Machines
I have a paloma tankless water heater, ptg-42pvn. It was flashing, C4, 13 and now it only flashes -0, 13 and will not even turn on. Tried to reset it by unplugging it and it only flashes -0, 13 even...
Multiple error codes can mean different things, including bad PC board.
C2 13 might be the oxygen sensor. -0 and no operation indicates bad board, but other things might be notched into same problem like loose connections.
Error codes are starting point for troubleshooting.
Before calling service technician, open following link for Rheem-Paloma troubleshoot resources including Rheem chat.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Sep 28, 2009 | Exercise & Fitness
Codes
NTL IRELAND (54 01) -- [Last Roll 13/06/2008 @ 7.15pm]
00 = 22 DO 9F EA FA CB 10 B3
01 =
9B 0B 4C 80 4F 6A 39 6B (new)
Please google for TheChatterbox TCB.cc they provide a free toolbar that gives access to new keys, I'm happy to help anyone where ever possible but these boxes are illegal when flashed and you really should sort them out for yourself.
Jun 13, 2008 | StarTech.com StarView SV211K 2-port KVM...
Looking for NTL ireland starview codes for 13 june 08
01 = 9B 0B 4C 80 4F 6A 39 6B (new)
Zanussi jetsystem Turbodry 1200
replace the circuit board
Feb 19, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
680 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
