SOURCE: the reverse gear is not working
You have to pull the push nuts off the rear axles with a pair of pliers.
I would check to make sure the motors are connected secure to the gearboxes. Usually if you have a gearbox problem it also affects the forward speeds.
The little tikes gearboxes are found at http://www.shopjandl.com/884931300.html but I would make sure the motors are secure to the gearbox.
hope this helps
SOURCE: tractor won't go in low gear or reverse
I had the same problem and replaced the shifter which I found at
http://www.mypegperegoparts.com/switches.html.
This fixed all the speeds and now it runs great.
Hope this helps
SOURCE: both wheels will not move in high gear, only one
how do i take a part the gear box from the motor
