Brother i searched for this fuc**n problem for 3 years . And i found the secret to fix this problem
First u need an android smart phone with IR support on it
Then install an app from app store its name Anymote
Then add me or msg me on facebook Cale mero
Or add me on what's app messenger my number
+201228046000
I will tell u what to do step by step
SOURCE: Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
SOURCE: hdmi grayed out in menu?
for this you must search other option in the menu to can activate this option but that you will find in your user manul because it is diffrent from one tv to other
SOURCE: cant find HDMI input on tv, trying to hook up ps3
hdmi output is" INPUT 1" on the menu ALSO hold down on the ps3 power button for 6 seconds and it should come on. the ps 3 has a thing were you have to set it to send out in hdmi or comp.
