Try clearing everything away from the bottom venting in the freezer and check for ice build up in the vents. Defrost it like you would in the "good old days" and to ensure it doesn't happen again, keep a 1" to 2" clearance in front of the vents in the freezer. If need be, set a cookie cooling rack on it's side to act as a barrier for the vents to ensure proper air flow.
SOURCE: Amana freezer is cold, fridge is not.
You will be able to hear it when you open the freezer door and hold the door switch in.It is located behind the rear panel inside the freezer. The fan should be running when the compressor is running. If it is running make sure the damper(vent) to the fridge side is not blocked by ice and that the damper door is open.
SOURCE: SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
SOURCE: hi i have a silver servis fridge freezer the
There might be problems with the freon all you need to do is to refill the freon into your fridge.
ERNZ
