I believe that this is a high-temperature error. so, you might need to move the printer to a cooler room or lower the temperature of the room that the printer is in.
Service Call
181: Error
182: Error
183: Error
184: Error
185: Error
Option unit I/F error
(181 = Duplex Unit.
182, 183, 184, 185 = Optional Tray)
Does this error recur?
Yes
Restore the power.
Check to make sure the contact points of the connector and replace the optional unit
Service Error 14 - PCL/XL software error. That's a main board fault. It may need a firmware update. That's a job for an OKI engineer as a mistake could destroy the board.
I have an Oki B6250 ang keep getting a Service Error 14. When i clear all the documents pending it works but happens next time someone wants to print Its linked to 20 PCs
The OKI B6100n Laser printer is a unique printer. These Error messages are to enable you detect the fault and resolve it if you can and the once you cant it resolve,u call the repairman.
The Service Error 02 means that there is a paper jam inside the printer and the only way to resolve it is to remove the paper from the indicated location on the printer. You can also check the user manual on the CD ROM of the printer for more information and how to correct similar error messages on the printer.
This error often comes when there an paper jam or paper tray 1 or paper tray 2 or 3 is empty,make sure that you have enough paper in the trays and secondly make sure that you have there is no paper jam in paper roller, even an tiny particle of paper can cause this error.
Please open all the access of your printer pull out all the paper trays and clean it properly with air blower, this can fix this error.
YYYY 106: FATAL ERROR An error has occurred which requires service. YYYY = the general cause. 106 = error number. Try turning off the printer then turning it back on. If this does not remedy the problem, write down the message including the error number 106, then call your authorized Oki Data Service Dealer for service. Note: If you see a series of octets containing letters and numbers scrolling across the display, be sure to write these down also and report them to the Service
Fuser error. Replace fuser or if no-go, Main board.
service error display
