stereo codes for Honda
Method 1 (all applicable models except '03-07 Accords with the
navigation system)
1. Turn the ignition switch to ON (II).
2. Turn on
the audio unit, and make sure you see
stereo COdE in the display. If you don't
see this message, pull the backup fuse for 1 minute, and then go back to
step 1.
3. Turn off the audio unit.
4. Press and hold the 1 and 6
preset buttons, then turn on the audio unit. The display toggles between
two screens. The first screen displays a U and the first four digits of
the serial number (for example, U2200). The second screen displays an L
and the last four digits of the serial number (for example, L0055).
Ignore the U and L, and write down all eight digits.
Method 2 ('03-07
Accords with the navigation system)
1. Turn the ignition switch to ACC
(I).
2. Turn on the audio unit, and make sure you see COdE in the upper
display. If you don't see this message, pull the backup fuse for 1
minute, and then go back to step 1.
4. Press
and hold the top halves of the SEEK/SKIP and CH/DISC bars, and then
press and release the PWR/VOL knob. This display toggles between two
screens. The first screen displays a U and the first four digits of the
serial number (for example, U2200). The second screen displays an L and
the last four digits of the serial number (for example, L0055). Ignore
5. Call Honda Dealer for
Radio Code.
6. Use the TUNE knob to enter the first four digits of the
anti-theft code into the audio unit. (Ignore the last digit; it's not
used.) When you turn the TUNE knob, COdE disappears, and a single digit
is displayed. Turn the knob left or right to select each of the
anti-theft
code digits. When you press the TUNE knob, the system beeps
and accepts each digit as it spells out CODE on the display.
https://radio-navicode.honda.com
