SOURCE: cannot pull rope out to start mower
Bad news , Mower has sit up too long and the piston / crankshaft has become rusty and froze in place. (fix) buy some liquid wrench it comes in a can at your local hardware store...Tilt the mower onto its front wheels and remove the spark plug. Fill the Cylindar with the oil and leave it for a couple days. after a few days lean the mower back and attempt to pour out the left over oil. Then (Check Your Oil level) preferable replace old oil and pull choke..and start mower...if the engine is still frozen (Buy a New mower) 125bucks Sears.
SOURCE: can't get my lawn boy started
check for a faulty wire to the engine kill switch it may be contacting the ground
SOURCE: lawn mower won't start, it backfires when string
You need to pull your flywheel and replace the aluminum key
SOURCE: I have a weed eater HD4QE22SC push mower that will
If it only runs for a few seconds after starting, the problem could be the main jet of the carburetor which is the brass bolt that holds the lower carb bowl on the carburetor. Remove it, inspect it and clean it...paying real close attention to the area on the bolt where there are no threads as there are very small holes there that have to be clear for the carb to get a continually good gas flow.
