Question about Boating
My 2001 115/HP Johnson outbd was starting hard last weekend. By Sunday it started to run ruff but would clear at higher power setting. When I pulled the boat out of the water I lowered the motor to drain the salt water out of it and got about a half cup of oil out the propeller. I just replaced the lower unit last year and do not believe their is a problem with it.
  • 677 Answers
The lower unit and oil draining is in no way related to the motor.They are two completly separate units.The g/box is totally self-contained.It sounds more like you have an engine problem.You don't say if the motor is carby or efi(fuel injection).If carby,The carby's are playing up.Be it float levels,stuck needle and seat.A prob.But not a big one.If it's an efi motor it needs to be serviced and so does a carby motor.You don,t have a big prob,just a service one.Hope this helps you
Posted on Sep 21, 2010
Testimonial: " Thank you. Its a carby and I was thinking it mite be a VRO2 pump. But I don t no how it works or if it part of the fuel pump."
6ya staff
SOURCE:
My 175 hp 1998 johnson (carbeurated model) is hard to start. When started it seems to run ok, but after motoring for 10 or so minutes, will just die.
Sounds to me that your carb is plugged up. I would take it apart and clean it. Also make sure your idle mixture screw is set to 1 1/2 turns out to start and adjust from there.
Aug 13, 2009 | Boating
70 hp Johnson hard to start.
could be the choke isn't closed all the way for the first start. Then when warm the motor doesn't need to be choked.
Jul 25, 2009 | Sport & Outdoor - Others
1985 40 hp Johnson outboard wouldnt open up and
sounds like your mix is off and it's fowling the plugs. probably too rich. make sure the level in your carb bowls isn't too high. Really sounds like you should clean and bench set your carbs. Especially if a plug change helps but doesn't last, then it's got to be your fuel mix, or maybe timing.
Jul 16, 2009 | Sport & Outdoor - Others
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Jan 19, 2009 | Boating
1991 deville idling very ruff
Hi you should change the coolant temp sensor this is a white sensor on top of the intake and is part ot the computer system.
Dec 30, 2008 | 1991 Cadillac DeVille
Hd52w59 - Me again....
sorry havent got back got some personal issue going on. So its cycling off. my fist instinct is to check the ribbion cables that go between boards. and most connectors. theres a cable that runs from the back green booard to the front center crt board in the front. this could be a problem. does the set make any noises?
Dec 28, 2008 | RCA HD52W59 HDTV Projection Television
Boating Logo
202 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
