Question about Bosch Axxis WFL 2060 Front Load Washer
When Washing on cold, cold water doesn't seem to come in to flush
The detergent down, like when I put it on warm.
I checked the water inlet strainers both at the ater tap and the strainers on the back of the washing machine. They were pretty much clear.
I discovered that the person that originally installed the washing machine had the hot and cold mixed up.
When I put the dial on warm I here the water flushing the detergent down in the top front where I put my detergent in.
6ya staff
SOURCE:
Simon Rankin
  • 5 Answers
SOURCE: Bosch wlf2260
I had a similar problem and found that the holes above the softner section were blocked by black mold. All I had to do was push a small wire into the holes to clear the blockage
Posted on May 16, 2007
Bob Gemmell
Bobby G
  • 212 Answers
SOURCE: Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Posted on Jan 03, 2008
jimrivers
  • 5 Answers
SOURCE: Bosch washing machine not drawing water
you probably have the "burst free" hoses, this machine draws water too fast so the hoses think they burst, change the hoses to the original or get new ones that aren't burst free and this should solve your problem
Posted on May 04, 2009
Anonymous
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
Leon Robinson
  • 747 Answers
SOURCE: The E:02 display was flasing with the spin light
try unpluging it for a few min. then plug it back in.
Posted on Jan 25, 2011
Lavamac front loading 28kg commercial washing machine(coin operated). When I press "cold" wash, why is the warm water coming out?
Your washing machine has to release some warm water even when liquid detergent is used. The purpose of the brief release of warm water is to dissolve powdered detergent and/or flush liquid detergent residue.
Jul 19, 2017 | Washing Machines
Fisher paykel gwl15 squeal while filling
1. Does the squeal go away if you choose a different temperature, eg, a hot wash?
2. Check the strainers/filters where the inlet hoses screw onto the washer:
- turn off water at the wall.
- start a warm wash to release pressure from hoses, then switch off machine.
- remove inlet hoses and inspect for blockage/debris. Then, place hoses directly into where the clothes go then carefully turn the water back on at the wall to check flow.
- Also check strainers/filters at other ends of hoses.
3. If all seems OK, new water valve(s) may be required. The rubber in the water valves can harden over time.
Aug 09, 2014 | Fisher and Paykel GWL11 Top Load Washer
Bosch Nexxt 700 Series Washer, water from cold supply does not dispense into detergent tray
Make sure that the cold supply is on and/or the supply hose is not crimped or clogged. Other than that it can be a control panel issue in the unit itself. But first eliminate the basic things.
Mar 25, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
Hello, I just installed a new 50 hot water heater..."ALL" th ewater supplies/outlests in the house work just fine... When using my Maytag top Loader for the first time on "Hot/Cold" setting, there is a...
Check the filters inside of the hot water inlet.
Try hooking the cold hose to the hot inlet to see if the inlet is blocked by debris.
You can remove the valve assy and flush it out.
Nov 08, 2009 | Washing Machines
The cold water comes out on a trickle. the warm & hot settings come out normal. nothing is caught in the line.
check the screens for dirt in the end of the fill hoses and the water inlet valve on the machine. you may need to try replacing the water inlet valve.
Oct 24, 2009 | Washing Machines
Warm wash is almost cold (no different from cool wash). hot water works fine.
What could be happening is the cold side of the inlet valve could be opening with the hot side and therefore it is warm instead of hot
Sep 07, 2009 | Washing Machines
No cold water
Check the strainer in the hose where it connects to the faucet.  If it is clogged it will slow the water flow.  There may also be a strainer at the end of the hose that connects to the washer.
May 30, 2009 | Washing Machines
Danby DDW396 Spray Arm
The spray arm is controlled by the force of the water. There is no motor running the spray arm. If water is not getting to the spray arm, then it won't spin. It may be plugged with detergent etc. Just a note re. detergent. You shouldn't use hard or caked detergents.
Dec 03, 2007 | Danby 22 in. DDW396 Free-standing...
Bosch Axxis WFL 2060 Front Load Washer Logo
116 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
