Televison & Video Logo
Posted on May 18, 2008
One green vertical line in HDTV Vizio 42
At left side across the screen one green vertical line is all time, what do you think about that?
Thanks
Karl
  • 4 more comments
  • Anonymous May 23, 2008
    me too....has anyone had vizio email them back from support.....I called and they wanted me to email a picture of my screen..crazy
  • Anonymous Sep 28, 2008
    I have same problem but red line
  • Anonymous Oct 09, 2008
    Mine is on the right
  • jason98 Jan 05, 2009
    Same problem but blue line
  • mattmckeon Jan 18, 2009
    one green vertical line on vizio 42" hdtv with motorola box
  • naclh2o4me Jan 31, 2009
    same problem: 5" wide vertical band of blue on right, and sometimes green on left edge. toshiba 42" lcd 120hz. could it be the hdmi cables are bad?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
8838
Points
14
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
Anonymous
Level 1:
New Friend:
  • Posted on Mar 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8838
Points
I have the same problen.Green line vertical on the right side of my screen.37 inch HDTV Vizeo.A year old.Please help
Anonymous
Level 1:
  • Posted on Sep 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
8838
Points
I got the same but red line
Anonymous
Level 1:
New Friend:
  • Posted on Dec 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8838
Points
Just had mine looked at. 50'' vizio plazma. was told it was a power supply moduale. economically not worth fixing. happened after lightning power surge.
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
1helpful
VIZIO 42" tv has thick black vertical line on left side of screen
The oven paper (referred as ovenable paper some time), is made of wood pulp, coated with food grade silicone oil. It features in smoothness, high-heat resistance and non- stick, etc. The brightness of baking paper is over 88. The sizing value of baking paper is above 0.8.Its strength is more than 3000.
I HAVE VERTICAL LINES AN 1/8" A PART ACROSS THE SCREEN, FROM ONE SIDE TO THE OTHER. I DO HAVE PICS
hi,if its not the scan board at fault,which i doubt,then its most likely screen(panel)failure.especially if they are red green and blue.
regards,steve
Fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
3helpful
3answers
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
1helpful
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Green vertical lines on the screen
Sounds like you may have some bad filter capacitors in the convergence board. Better take a close look at them before they damage the chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
