SOURCE: the 4-wheel drive will not engage on my 2005 sportsman
jack up again and with it running in park or neutral move switch in and out of 4 wheel and listen 4 the actuator to move if it sounds like its binding or humming or does nothing if binding un bolt from front end possible and check if actuator rod is bent or needs lube alot of times the actuator needs to be cleaned and lubed if their is nothing no sound or movement test actuator if shorted damaged repair or replace as necessary
SOURCE: one wheel pulls
That is how it is built...one wheel is for forward the other has a seperate motor for reverse, it is ok.
I had the same thing happen to me today. I jumped it, when I landed (while I was on the throttle) something gave. The rear wheels won't pul
