Speed Queen AWS75NW Top Load Washer Logo
Posted on Apr 20, 2017
My Speed Queen Top Loader heavy duty washer is from around 1988. It has long worked well, but now has problems. First it stopped completing tha wash cycle, halting in the soak cycle. Turning the knob a little would cause it to resume. Now it is even more off - Last time I started the machine it immediately began the spin cycle. I stopped that, turned the control knob and restarted. The full cycle began, completed, and then restarted again. There is something wrong with the controller. I opened it up but the closest thing to a part number is RSFC 29966. Thanks for any help.
1 Related Answer
Terry Schneider
  • 177 Answers
  • Posted on Jul 08, 2008
SOURCE: Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
1helpful
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Does the top loader heavy duty machine have a filter and does it need to be cleaned regularly. If so, where is it located?
No filter to be cleaned in the machine. There are however small wire mesh filters in the screw on connectors that connects the water hoses to the machine at either the tap side or where it are connected to the machine inlets. Unscrew the hoses from the tap and machine inlets and check both hose ends if the wire filters are not to clog up over time resulting in slow water filling of the machine. Remove carefully and clean with a nylon brush. Replace again.
Motor rund but drum dont spinon speed queen heavy duty washer
Fluid Drive clutch greasy or worn,
Pump blocked or drive belt too loose
Speed Queen Top Loader Spin cycle problem.
Check the belt and idler pully
The pully shoud turn freely
2helpful
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
2answers
Kelvinator or (Speed Queen Top Load washing machine)
You probably have the wrong belt, and its to small? Go to repairclinic.com or google Kelvinator parts. Order the correct belt.
Top Speed Queen Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
