Question about KitchenAid K45SS Classic Stand Mixer
Mixer speed fluctuates; is too fast on low gear
I'm trying to fix a Kitchenaid K45SS. The slow gear runs way too fast, and when on the slower gear the speed fluctuates. Is it likely to be a problem with the switchboard, or the governor?
  • 1 more comment
  • johnnytexas Jun 17, 2008
    Thanks much.
    Thanks much
  • Anonymous Jun 17, 2008
    I also have the same problem but my model is a KA45. I dissasembled it and I notice that a part (made of something like ceramic with a wire on each side) is burnt. I believe it is a resistor or a potentiometer and I wonder where I can get it. I will appreciate any help. Samo
    Dedicated:
    Visited the website for 20 consecutive days.
  • KitchenAid Expert
  • 169 Answers
Hiya,
Sorry to hear you are experiencing an issue with your appliance.
We have created some videos, that might help you resolve this issue. Please see one of the links below:
https://www.youtube.com/watch?v=bM3t46afGcc
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidMixerHelp/KitchenAidSpeedSettings/tabid/615/Default.aspx
Posted on Sep 27, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: kitchenaid mixer k45ss slow gear
If you look into the brush holder you will see a stopper at the botom ,(this is so when brushes are wore the spring is not driven into armature) .. the brushes have to be inserted so the groove is lined up , try that
Posted on Apr 07, 2008
Dan Hudson
  • 118 Answers
SOURCE: Repair manual for a KitchenAid K45SS stand mixer
You should be able to look up your manuals HERE
Posted on Nov 30, 2008
Anonymous
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
Anonymous
  • 135 Answers
SOURCE: Need Kitchenaid k45ss manual
Hi. All of you should goto www.kitchenaid.com and enter your model# into the search window. You can download Operators and Parts manuals for your model. Kitchenaid does not provide Service Manuals but the parts drawings will be very helpful with disassembly and reassembly.
If this solution has assisted you, please rate. ricardok45
Posted on Mar 22, 2009
Bob Hewitt
  • 130 Answers
SOURCE: Kitchenaid K45SSWH Mixer only starts fast then sometime slows
You can try adjusting the speed control as shown in section 6 of the service manual:
http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Also remove and clean the brushes as shown in the same manual pg 8 fig. #30.
Posted on Apr 19, 2010
K45 kitchenaid mixer quits working under load? When beating egg whites it works great but try to cream butter and the beater stops.
It will be a broken or missing pin through a gear or the planetary or something wrong with the fuse gear. It should be easy enough to find but you will need to split the gearbox cases to check.
Sep 17, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer K45SS only has one speed, slow. Have taken apart and regreased the machine. I plugged it in while the planetary head was off and it went through the speeds as normal, but as soon as
Did you clean the are around the variable-speed control lever?
Please be sure to unplug the mixer BEFORE disassembling the mixer.
http://www.ereplacementparts.com/kitchenaid-k45sswh0-classic-stand-mixer-parts-c-114958_114959_115060.html?page=4
http://www.ereplacementparts.com/article/11983/How_to_Replace_the_Speed_Sensor_and_Control_Board_on_a_KitchenAid_Pro_6_Mixer.html
Jan 07, 2014 | KitchenAid K45SS Classic Stand Mixer
KitchenAid mixer speed surges high and low uncontrolably
You can get the high speed back if you want to play with those three screws. there is a timing scheme for your mixer and it is set and adjusted by manipulating those 3 screws. The bottom center screw is for speeds 6 8 and 10. The best choice is to replace this switch, about $10 bucks on ebay.
Nov 13, 2012 | KitchenAid K45SS Classic Stand Mixer
On low it makes a really loud grinding noise the higher you turn up the speed the slower it becomes.
It sounds like the Worm Gear is going out. The faster the motor runs,
the more damages the Center Gear is grinding away the teeth of the
Worm Gear. Things start to slow down, and eventually they will come
to a halt. It's time to replace the Worm Gear. Also make sure to use
new fresh Kitchenaid Food Grade Grease with the new replacement.
Jun 19, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
I have a Hobart KitchenAid Mixer Model K45SS and it runs fast on low (Surges speeds up and down)what is causing this problem
Hello Mayfix,
The problem with your mixer is the speed control switch, this switch is located at the back of the unit. It is usually black and has all of the wires coming into it, the Item # 1394070 and cost $27.95 it can be located at RepairClinic.com he is a link
http://www.repairclinic.com/Kitchenaid-Switch-Parts?z=100&gclid=CKSD5NriuKcCFUVqKgodIE2b_g
You will have to adjust after you install you will adjust the two screws at the top of the switch while the machine is running inorder to make sure that you are getting all the speeds. Be careful as there is a possibility of electrical shock if you touch the wronge thing.
Thank you for using FixYa.
Jul 04, 2010 | KitchenAid K45SS Classic Stand Mixer
Speed is off, only have fast and faster
Likely, you have an open resistor pack which may or may not be repairable located near the rear of the motor housing. Hope this helps!
May 23, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer running too fast.
Change the speed control board. Repair alot of these
Dec 24, 2009 | KitchenAid K45SS Classic Stand Mixer
Grinding sounds and slower mixer speeds
It sounds like you may have a broken worm gear inside your mixer which is a common problem.It is a wearable part which transfers the power from the motor to the main drive. It may be chipped or damaged right now, and running it will cause more damage. Part number for the worm gear is W10112253. This does however require some know how to replace. Hope this helps
Thanks
Nov 21, 2009 | KitchenAid K45SS Classic Stand Mixer
K45ss kitenaid mixer surges at low speeds
Hi. Go to mendingshed.com and download their free Kitchenaid Service Manual. This valuable document will help you to tune up your mixer, and covers the K45SS model. They also sell kitchenaid parts.
Go to kitchenaid.com and search for a parts manual for your mixer. Enter your model# thusly k45sswh.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Apr 12, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid 250 watts k4ss mixer
The repair manual says that the mixer can make this grinding sound at slow speed, like stir or 2. This is normal, especially until it warms up. This is the sound of the gears turning at slow speed.
Dec 13, 2007 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
217 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
