SOURCE: how to fold bugaboo camaleon
Put the seat in first (upside down, with the back of the seat facing up). Then put the collapsed chassis (with the large rear wheel taken off) on top of the seat. Make sure the front wheels are facing up. The handle bar goes towards the skinnier part of the travel bag.
SOURCE: Packing Stokke Travel Bag with the Chassis - bassinet
Hope I can help you out with this...for me it was quite easy once you get the hang of how to fold the stroller system at the smallest possible fold. You have to have the seat at the lowest position, next you fold the front wheels inward so that it is flat against the stroller, then fold the handle all the down toward the stroller frame so that it is flat. NOW you have the stroller at the smallest fold. Remove the SEAT from the Stroller frame and place it on top of the stroller (FYI - the adjustable foot plate should still be attached to the SEAT and it fits directly ontop of the 2 metal pieces that protrude from the stroller that you normally instert the seat into)
NOW it will fit inside the Stokke Travel Bag.
SOURCE: Hi, i have just purchased a travel bag for my
You must completely un-assemble the stroller before storing it in the travel bag. That means removing all four wheels and detaching the bassinet fabric from the frame before placing it in the bag. There should be a diagram on the inside side of the bag which describes the order of placing the parts in the bag. The order from ground up is the seat frame with the fabric, then the stroller chassis, then the wheels.
SOURCE: sticking front wheel on bugaboo frog won't swivel properly
There should be a master degree on the subject of using and folding strollers...
I do not know this stroller, but the try the link below.
On right hand top of the page you will find LIVE HELP... They should be able to help you solve this..
http://www.bugaboostrollers.com/home.jsp
Good luck! :)
Cathy
SOURCE: Where can I find instructions on how to dismantle
Bugaboo have user guides on there web site. www.bugaboo.com/user-guides
