SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: Frigidaire Affinity dryer error code?
I have an affinity dryer that has dn displaying on the in the digital read out what does this mean
SOURCE: Frigidaire Affinity Atf7000e...Does not load up water.
clean your inlet screen...onthejob...take hose off and take screens out of inlet water vavle and clean then replace..onthejob
SOURCE: Frigidaire Affinity Error Code EFO
We got the same error. After searching countless forums, we found the solution! There were socks/underwear/change built up in the pump. The water was not cycling through properly. It didn't even get passed the wash cycle. Cleaned it out and everything works fine. Plus, the error code list is INSIDE the washer! Go figure.
SOURCE: How do I go to clean cycle-Frigidaire affinity ATF6000fs
First, you put some bleach or tide washing machine cleaner inside. Then you make sure the washer is on and hold the spin speed button and the options button down at the same time for 10 seconds. You will see "Cln" appear on the display screen. Hit start and you are golden.
