Watches Logo
Posted on Sep 13, 2010
I have a TCM radio controlled mans watch , I have replaced the battery now I cant put the watch at the right time can you help please
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1586
Points
2answers
I have a radio controlled clock I bought from Aldi I cannot get the time to set from the time signal can you help please
Depending on where in the world that you are, the time signal might bot be strong enough to reach you.
Dec 18, 2012 • Watches
2answers
Klik radio controlled watch
Why would he need the manual to do that ???
The time is self setting !
and to chage the battery just take out the back cover and slide the pin holding the battery in place, and replace it with the with similar battery...
I will try to find the manual for you..
post back in a second
Jan 09, 2008 • Watches
I have a one year old berenger atomic time watch that has stopped working last week. May I perhaps need to get a new battery/ What does radio controlled watch mean? Thanks
I would try replacing the battery in your watch to see if it comes back to life. So-called "atomic watches" have tiny radio receivers in them that periodically listen for the official atomic time being broadcast via WWVB in Colorado. However, as you might imagine, it takes a lot more power to operate a radio receiver than it does to power a typical quartz wristwatch, and even with larger-capacity or double batteries, it's been my experience that these watches burn through batteries more quickly than traditional "set them yourself" watches.
An additional factor is that a watch that cannot find the WWVB signal will scan for long periods of time before putting its radio receiver into hibernate mode. So, if your watch has been stored in a basement, an interior room in a large building, or some other place where a radio signal can't penetrate, that would also shorten the watch's battery life.
May 10, 2011 • Watches
1helpful
I have a black and dark grey digital watch marked TCM on the back with 4 buttons saying "bearing", "start/spl", "mode/select", "stp/light/set" around a circular digital face. On the back it says that it...
  1. Hold and press upper left. (backlight turns up and cipher (to adjust) start blinking)
  2. Switch between the positions by pressing bottom left
  3. Set the cypher you want by pressing bottom left
  4. Repeat step 2 and 3 each time you need
  5. Press upper left to end of adjusting
To use the compass - upper right. To callibrate and set the declination, please search it. I just post that answer to another TCM 217362 watch owner.
Oct 21, 2010 • Watches
I love my E. Howard radio controlled watch. I recently had the battery replaced by a local jewelry shop but it no longer keeps accurate time!It is about 55 minutes fast and remains that way. What do I do...
mcdevito75 here, Return to the shop that changed the battery for adjustments, possibly a new battery or the factory recommended type battery.
Jul 22, 2010 • Watches
18helpful
2answers
Roberto vecci radio controlled watch instructions i cant set the analoge time
i HAVE RDIO CONTROLLED WATCH NUBER 02390 PUT A NEW BATTIER INIT BUT i CANT GET IT WORK RIGHT,DAVID
10helpful
I have lost the instructions and cant set the time
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please .
Mar 27, 2010 • Watches
Replaced battery in mfj 188mrc need to reset
http://www.mfjenterprises.com/man/pdf/MFJ-188MRC.pdf
Apr 07, 2009 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
