The only issue i can see is if your your ram has not been updated since leaving the factory, you will notice from the tables W7 requires a min of 1GIG and your machine leaves the factory with 256mb(dependant on country possible) so check your ram.
I run windows 7 on 2GB and its great, your machine will take 2GB.
The Samsung X05 was released 2004 and the NVIDIA Geforce 4 should be fine.
i would point out drivers and compatability but windows 7 so far is really good but driver support is crucial
hope this helps
Here is the requirements for Windows 7
Windows 7 minimum specs
1GHz CPU
1GB of RAM
16GB of drive space
DirectX 9-capable graphics card or integrated chip (true of most releases 2002 and after)
BELOW YOUR MACHINE SPEC
MPN nx05tp8e0a/suk Key Features Laptop Type Thin and Light Laptop Use Corporate Business • Small Business • Business Processor Pentium M 1.5 GHz Installed Memory 256 MB (DDR SDRAM) Display 14.1 in. XGA TFT LCD Operating System Microsoft Windows XP Professional Mobile Technology Intel Centrino Mobile Technology Processor Processor Manufacturer Intel Processor Type Pentium M Processor Speed 1.5 GHz Motherboard Chipset Intel 855GM Bus Speed 400 MHz Memory Installed RAM 256 MB RAM Technology DDR SDRAM Max Supported RAM 2 GB RAM Speed 333 MHz Installed Cache Memory 2048 KB Hard Drive Hard Drive Capacity 30 GB Storage Controller Type Ultra ATA 100 CD / DVD CD / DVD Type CD-RW/DVD-ROM Optical Drive Read Speed 24x (CD) • 8x (DVD) Optical Drive Write Speed 8x (CD) Optical Drive ReWrite Speed 8x (CD-RW) Display Display Tech XGA TFT LCD Screen Size 14.1 in. Display Max. Resolution 1024 x 768 Video Graphic Processor NVIDIA GeForce4 440 Go Graphic Bus Interface AGP x4 External Video Resolution 1920 x 1200 Audio Audio Output Type Headphones • Sound card • Speaker(s) • SPDIF out Audio Input Type Microphone Operating System Platform PC Technical Features Expandability 1 x Type I/II PC Card Slot, 1 x Memory Stick Card Slot Expansion Ports 2 x USB 2.0, 1 x IEEE 1394a (FireWire), VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out Input Method Keyboard • Scroll Button • Touchpad Networking Networking Type Integrated 10/100 Network Card • Integrated Wireless LAN Data Link Protocol Ethernet • Fast Ethernet • IEEE 802.11b • IEEE 802.11g Modem Modem Type Fax / Modem Analog Modulation Protocol ITU V.90 Battery Battery Run Time 2.2 Hours Battery Technology Lithium ion Dimensions Width 31.5 cm Depth 25.9 cm Height 2.4 cm Weight 2 kg
Link to all drivers for samsung X05
http://www.samsungpc.com/products/x05/x05_supporteddrivers/x05_supporteddrivers.htm
First check drivers are installed or no conflict etc
START>Computer (RIGHT Click)>select manage>Left click device manager
In the list check your network adapters, also being wireless check for broadcom 802.
Some wireless laptops have an external light and switch
hope this helps
