More and more people today tend to forget or lose their Windows 7 password under such a high-pressure society. Then what would you do to handle with that should you experienced the same trouble? Actually, all you need is only a "password reset" disk. A
Windows 7 password reset disk could help you to reset Windows 7 password and regain access to your locked Win 7 PC. Here we will share two methods to create such a disk with you. So let's roll it.
Method 1: Through Windows 7 operating systemRequirement:
1. Be able to log on Win 7 operating system with the password
2. A USB flash drive is required
Windows 7 was designed to be able to create Windows 7 password reset disk without any other third party tools. So if you forgot the password for your user account and was unable to log on, then you could use the disk to reset Windows 7 password. Now you could follow these simple steps to create one.
Step 1: Start your computer and log on Win 7 operating system
Step 2: Insert an USB flash drive into your computer
Step 3: Click Start -> Control Panel -> User Accounts and Family Safety -> User Accounts -> Create a password reset disk
Step 4: You will see the welcome screen. Click Next
Step 5: Select your USB flash drive. Click Next
Step 6: Type the login password in the password field. Click Next (now Windows 7 operating system should automatically create the disk for you)
Step 7: When the processes finish, Click Finish to exit
Now you have successfully created a Windows 7 password reset disk. And you will be able to use this disk to reset Windows 7 login password by following the whole processes of
Windows 7 password recovery if you
forgot Windows 7 password.
Note: One disk can only work for one account. You could not use this disk to reset the password of another user account.
Method 2: Try Windows 7 password reset softwareRequirement:
1. An available computer with a CD/DVD burner
2. Windows password recovery software
3. A blank CD/DVD or USB flash drive
There is plenty of third party
Windows password recovery software on the Internet. All of them were designed to create a Windows password reset disk. If you forgot to create a Windows 7 password reset disk when running Win 7 operating system before losing your password, then you may have a try on this method. The benefit of this method is that you could create the disk any time and do not need to know the Windows 7 password. Here we highly recommend Windows Login Recovery and will take it as an example to explain the procedures.
Step 1: Download Windows Login Recovery and install it onto an available computer
Step 2: Run the software and use it to burn a Windows 7 password reset disk (you could burn the file onto a blank CD/DVD or an USB flash drive)
Step 3: Change the BIOS setting of your locked computer to make it boot from the optical drive
Step 4: Boot your locked computer from the created disk and reset Windows 7 password
If you do not think these steps are distinct enough, you could also view the detailed user guide at recover the forgotten Windows password. By the way, the disc created through this way can reset the password of all the accounts instead of only one account.
Forgetting Windows 7 password is really a problem. But now you needn't worry about that any more. You could easily
reset Windows 7 password with your
Windows 7 password reset disk in the future.
