Hitachi 55HDS69 55 in. Plasma Television Logo
Anonymous Posted on May 14, 2008
Plasma tv what is the problem if the tv is automatic turn off while not pressing the power botton and not set the program sleep time so ineed your'e cooperation and give me some idea what im going to do
Anonymous
Level 1:
  • Contributor 29 Answers
  • Posted on Dec 30, 2008
Anonymous
Contributor
Level 1:
Answers
29
Questions
0
Helped
27701
Points
49
The pilot light is in blue or red??
Is blinking after turn off??
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
Why does my hitachi plasma turn on and go right back off
Denise
Have you tried checked the cables, power and knobs?
then try in time settings- in auto sleep, probably set in sleep timer.
kolbrun
Need code
I HOPE THIS HELPS... YOU DIDN'T GIVE US MUCH TO GO ON....
BEST WISHES!
GE Universal remote controls - instructionsHow to Program a GE Universal Remote Control
Programming a GE/Jasco Universal Remote Control is simple, requires only a few simple steps. You need to know the code of device you are programming into the remote. See the GE remote control codes page for3 digit or 4 digit GE remotes.
How to enter codes manually:
Step 1: Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
Step 2: Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
Step 4: Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
Step 5: Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
If you can't find a working code for your device or your brand is not listed try the "Code Search" method described below.
The CODE SEARCH function
Step 1: Turn on the equipment you wish to program.
Step 2: Press and hold "CODE SEARCH" or "SETUP" until the light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). The indicator light will blink once, then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
Step 4: Press and release the "POWER" button until your device turns off. Wait at least two seconds between each time you press "POWER". Note that you may have to press "POWER" up to 250 times!
Step 5: When your device turns off press the "ENTER" or "SAVE" button. The indicator light will turn off. Check other functions to see if your code is correct.
The SLEEP feature
Some GE remote controls like the RM94902, RM94904 or RM94905 have a handy "sleep feature" enabling you to turn off your TV after a preprogrammed time interval of 1 to 99 minutes. To use the sleep feature follow these steps:
1: Press and hold the "SLEEP" button until the indicator light turns on.
2: Enter the time interval in minutes using the numerical keypad. (for minutes from 1 to 9 press 0 before the actual number).
3: Leave the remote aimed at the television set.
To turn off the sleep feature, press and hold "SLEEP" until the indicator light blinks or press the "POWER" button to turn off the TV.
http://www.eliztech.com/remotes/ge-howto.php
9helpful
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
2answers
My tv turns off automatically
I think your TV was set to turn off by itself automatically. Try to reread the manual about it.
1helpful
Need code for programming rca tv wiht a sony
find the correct code automatically.Turn on your device.
while pressing SET botton press POWER, and release them ,then press CH+,then release it
Then press POWER repeatedly untill your device responds.don't go too fast.
When it responds press ENTER to store the code.
5helpful
7answers
SVA PLASMA TV
I got this same tv from a guy in my area he would press the poewer botton on the tv and the standby light comes on and then turns off, so he gave me the tv for free i took the back panel off, and everytime i press the power botton the green light came on where the screen board is and went back off after i let the botton go i took the power board out took it to a repair shop to see if there was anything a wrong with it everything was good so i replaced the two fuses on the board and the one on the screen board, i had a feeling about the power switch so i jumped the wires on the switch purple to purple and green to green, I put it back together pluged it in the standby light came and stays on now, so i went out and got a universal remote for the sva at walmart for $15 programed it and pressto the tv works perfect so three fuses $3.60 two small pieces of wire and ele tape $0 my time 35 mins = one working plasma for $3.60 so when you have this problem like everyone else check the power botton switch, there cheap and check the fuses theres only three and if that dont work idk what to tell ya. and you do need a remote or tv wont work.
TV CUTTING OFF
Check this, for how long the TV is on? 30 min., 45min, 1 hour? because maybe you have accidentally programmed the SLEEP control. If so, go to the set up options or menu with the remote control and check the status of the sleep power off time. Or maybe the TV has the otion to power off automaticly set the same way that is the alarm turn on.
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
