Frigidaire ATF6000ES Front Load Washer Logo
Posted on Mar 01, 2018
My 2008 Affinity front load washer has worked fine since I bought it. Recently I did something for the first time...I only wanted a Final Spin so I entered that. Now it will not drain at all. Cancelling the Final Spin request does not work. model: LTF6700FSO serial no: XC84801609
5 Related Answers
A
Anonymous
  • Posted on Jun 02, 2008
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Anonymous
  • Posted on Mar 22, 2009
SOURCE: affinity will not do final spin
sure you have fixed by now but i found that i released the plug and it was right again. also I find this happens when there are too many heavy wet towels in load.
cjfmc
  • 39 Answers
  • Posted on May 22, 2009
SOURCE: frigidare front load wnot drain on final spin
Sounds like the SPeed Control Board is now good
Anonymous
  • 14 Answers
  • Posted on Sep 11, 2009
SOURCE: My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Anonymous
  • Posted on Jun 25, 2010
SOURCE: Won't drain
dude totaly fixed the problem, i pulled off the one hose clamp underneath and shazam, out pops two baby socks. best advive to give above the last is take your time putting that hose back on. i had to do it three times before i was happy with it on all the way. feal with your fingers around the lip in the back to see if its not crooked ( it works its way off as you tighten and ffigit with it all. and the lip the hose fits on is small. )
thanks again for saving the day
My front load washer wont go into final spin and clothes are soaked
What is the model number of the unit?
Try running it in a different cycle to see if it does the final high speed spin.
Post back the results.
2helpful
3answers
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
3helpful
Frigidare affinity model # atf6000es won't spin in
sometimes in the bottom right hand corner of the machine there is a little face plate and allows to you unclog foreign material that collect over time.
1helpful
1helpful
Final Spin Cycle gets stuck at 1 minute
back tub bearing,,and spin surport,,defective,,,under warranty,,,call for service..onthejob
1helpful
2answers
Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
4answers
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
