Hi :
I'm trying to locate a evap fan motor for a DANBY wine cooler.
The model # is - DWC282BL
The part # is - JG32DQ-02
I didn't have luck locating the part at sears..Jean
Call Danby at 800 263 2629, you can order parts from them
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
My wine cooler is not cooling. I found that the fans are working, but I think the compressor is not pumping. The compressor will come on, but the temperature keeps climbing. do you think the compressor is going out ? Or do the leads need to be taken off the compressor and cleaned.
wine cooler not cooling. Could it be the compressor. How can I make sure compressor is running?
