We changed the head gasket and put everything back together and now we cant get it to start. we even put in new spark plugs. is the gap supposed to be at .44 or .42 which?
Pull the spark plugs not the wires but the plugs themself make sure they are gapped right to your car and they are not wet in any way you might be getting spark but if they are wet you mise well forget it and just buy new plugs they are like 2 dollars a peice
The head gasket needs replaced. This particular Saturn is known for having this exact problem, and 9 out of 10 times, replacing the head gasket fixes it. I just did it myself for $35.
Go to checker/autozone and get a head gasket (should just need the gasket and not the entire kit) and a tube of RTV silicon grease to help make the seal.
Unhook everything from the engine (plugs, wires, etc, and unscrew the head. There should be about 10 or so screws surrounding the black plastic head cover. You'll find things a mess in here, but clean it up best you can. Remove the old gasket and clean the entire gasket area completely and make sure its dry. Put down your RTV grease, the new gasket, some more RTV, and screw the head back on. MAKE SURE YOU DON'T SCREW IT TOO TIGHT. The screws only need to be snug. Tighten it like you would a spark plug. Put everything back together and you should be good to go. Might run like **** the first half mile or so.
plug gap 25 th ,too wider gap and it will be hard starting from cold ,as for idle then this could be a vacumn hose perished or not reconnected when head gasket changed ,or a vacumn pipe has been damaged whilst changing the head gasket follow then all back even the best of us inadvertantly damage things or drop a bolt somewhere that always rattles afterwards
Have you cleaned the spark plugs? they will surely be filthy after a headgasket failure... maybe even cracked by the water going on the hot plug... I recommend changing the plugs before trying anything else.
1995 FORD RANGER 2.3L
