Clarity Knee Walker Leg Scooter Ankle Surgery Crutch Rollator Logo
Posted on Sep 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the advantages to having a 4 wheel knee walker versus a 3 wheel knee walker
gavin jones
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,508 Answers
  • Posted on Sep 02, 2010
gavin jones
Master
Level 3:
Renaissance:
Answers
1508
Questions
0
Helped
483812
Points
3349
The 4 wheelers are generally more stable, the three wheelers are more manouvrable
  • GdbyeCrutchs Sep 15, 2010
    The major things to look at are wheel diameter (the bigger the better), make sure it turns, and finally that the knee platform can be offset for left or right leg which keeps you from kicking the back wheels with your good ankle and greatly improves stability. Good article on line at Ezine "What to look for in a knee scooter? "
1helpful
2answers
4answers
Do you have any suggestions for mitigating knee pain?
Knee pain is not a rare problem. It happens due to the tearing and wearing at the knee joint. Every one can have this problem, women are more prone to knee pain. To treat it effectively, the simplest way is applying cold compress because it can constrict the blood vessels and then reduce the blood flow coming to the pain area. as well as relieve the swelling.
Reference: Home Remedies for Knee pain- Authority Remedies
1helpful
How can I find instructions or a manual for nova knee walker?
Hi Chris,
I've linked to the manual for the Nova Knee Walker below.
Regards,
Martin
www.kneewalker.ie http://novamedicalproducts.com/downloads/knee-walker-guide.pdf
Dec 02, 2014 • Baby Gear
2answers
I love walking and go with my friend three times a week. How do you prevent knee pain?
Knee/ shin pain is a very common problem with walkers. Here are some tips to help prevent it;
- Wear good walking shoes that are supportive
- Do stretching of calves and shins before and after you walk
- Build up your distance gradually
2008 pontiac g6 steering wheel removal procedure
Turn on your car. Turn the steering wheel so the front tires are pointing directly forward. Turn off your car.
  • Pop the hood on your car and disconnect the black and red battery cables from the battery with pliers. By disconnecting the battery you will prevent the airbag and horn from malfunctioning or blowing.
  • 3 Take the center cover off of your steering wheel. There should be four to six screws on the back side of the steering wheel. Unscrew these, then pry the cover off with a flathead screwdriver.
  • 4 Remove the retaining clip on the center of your steering wheel with pliers. Place the correct size socket on the retaining nut, and loosen the nut, unscrewing it one turn.
  • 5 Lie back in the seat and prop your knees under the bottom/sides of the steering wheel. Apply pressure on the back side of the steering wheel with your knees by pushing on your toes.
  • 6 Place the rubber mallet over the retaining nut with your left hand. Apply pressure with your knees. With your right hand, bang on top of the rubber mallet until the steering wheel pops loose.
  • 7
  • Unscrew the retaining nut completely and remove the steering wheel.
  • 0helpful
    Do baby walkers teach babies to walk?
    If only it were that easy :) I don't suggest you let your baby use a walked until he or she is very strong on their feet. Since walkers are on wheels, it's really easy for babies to fall and hurt themselves as the wheels more the walker too fast.
    Jan 30, 2013 • Baby Gear
    Front Wheels jammed up. Replace or cleaning tips?
    I have the same issue did you ever get that fixed? I was able to clean the back ones with out a problem.
    How to adjust parking brake on winnie lite 3 wheel rollator
    For openers "LOCKING" handles)...
    Very GENTLY would be the first caution..
    Unlike the brakes on those long ago bicycles we used to have... these WALKER BRAKES are pretty cheesy plastic...
    None of the ones I've been compelled to work with have
    interchangeable parts... SO BE GENTLE.
    Look at both ends of the cable of the first wheel you want to adjust...
    You are looking for a threaded sleeve with a nut on it...
    If the brakes are too tight you will want to shorten the sleeve...
    Too loose you will want to lengthen it (tightening the cable).
    DO NOT overtighten...
    These are all plastic... cheaply constructed... but EXPENSIVE to replace.
    I have had to hand craft REPLACEMENT PARTS to repair these things (nothing is STANDARD (but the careless attitudes).
    When you do break'em... AMAZON had the greatest selection...
    (knowing the mounting diameter, and cable length is imperative
    (sold in PAIRS)).
    Carnac the Magnificent
    Remove and replace steering wheel
    its simple take horn botton off if it has airbag remove battery cable first airbag has a 4 bolts in back of steering wheel take them out after u take the air bag off u will see a nut in middle off steering wheel take it almost all the way and take your put your knees against the back off steering wheel then hit the nut with a hammer push with your knees as u hit it. thats the cheap and easiest if u dont have steering wheeel puller u can rent one at autozone or advance
    Top Clarity Health & Beauty Experts
    Rob Hill
    Rob Hill
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Clarity Health and Beauty Expert? Answer questions, earn points and help others
