Bosch Axxis WFL 2060 Front Load Washer Logo
Posted on Aug 21, 2017
Bosch Maxx WFL 2060 Hello, my washer gets part way through a cycle then halts (early in the cycle) and the red indication light changes from 'Active' to 'Ready'. If the Start button is pressed again the washer restarts the cycle but will again halt and return to 'Ready'. Any thoughts on why? It doesn't happen all the time and will sometimes run a whole cycle without interruption.
5 Related Answers
Anonymous
  • 130 Answers
  • Posted on Jan 28, 2008
SOURCE: Bosch Maxx lights on, hit Start as normal but nothing happens. After a while it goes back from Active to Ready flashing.
First question is does the display light up? If so then does the door lock? If the door is locking then the fuse for the washer that is on the back of the dryer hasn't blown. However if door won't lock, then check the fuse to see if it is open. This is a 208/240 volt washer and the display is the only part that doesn't need 208/240 volts. If fuse if find, then check the water screens in the fill hoses and clean them. This may be more of a control unit issue having failed, Hard to tell without knowing age of unit. Hope this helps
douglas smith
  • 1462 Answers
  • Posted on Sep 13, 2008
SOURCE: Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
shaun taylor
  • 1527 Answers
  • Posted on Jul 21, 2009
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
mnwarfield10
mark warfield
  • 453 Answers
  • Posted on Dec 30, 2009
SOURCE: The drum stopped turnig and there seewms to be no
you need to test the motor to see if voltage is getting to it.. if yes change brushes or motor complete...01179512835
Testimonial: "spot on thank you"
Anonymous
  • 228 Answers
  • Posted on Feb 17, 2010
SOURCE: The water does not cutoff during rinse cycles
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
2answers
Bosch wfl 2050/2060 washer door is jammed and will not open
talked with bosch rep-- said there is no manual door release
4helpful
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
2helpful
The drum stopped turnig and there seewms to be no life in the motor on our BOSCH Maxx WFL 2060 does any one have any idears. Thanks
1helpful
2answers
1helpful
2answers
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace [email protected] , [email protected]
Bosch Maxx WFL 2060
1helpful
2answers
Flashing Active Light and not taking fabric conditioner
1: The flashing wash light usually indicates a problem with the door latch while a flashing rinse/spin light usually indicates a problem with your inlet valve. 2: The cold water inlet has 2 independant outlets. The issue that you are describing indicates that one part of the cold water inlet is not opening to allow water to flow to the proper dispenser port.
Washer only seems to work on 40 degree cycle
check to see if this model has 2 water inlet hoses
if there is 2 only 1 may be used and is connected to hot tap thus only letting in hot water when machine requires water
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
