The FL error code means:
Flood Condition: FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
The problem on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.The other possibility is door lock latch got faulty and needs to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
There is a backup valve or flap in the drain assembly that seems to sometimes cause problems with the FL error code.
