Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sounds like you are starving for fuel. This can be a clogged fuel filter (old gas around the outside of it), a cracked fuel line, or the diaphragms in the carburetor need replaced. Make sure you the fuel filter is clean. Clean it off with some gumout spray. If your fuel lines are not cracked, then I would suggest a new diaphragm kit in the carburetor. Not sure of your mechanical abilities, so I don't know how hard or easy that would be for you to do.
