Ovens Logo
Posted on May 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tricity bendix double oven
The grill works and the top oven but the main oven does'nt work the clock is flashing with auto at the side there are only 4 push buttons on the oven and one small knob to turn. two buttons have arrows pointing sideways one button looks like a small steaming pot the other button don't know.how do you go about setting the clock and getting out of auto mode
thanks in advance
ciffbuck
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
641
Points
My oven's fan is working but no heat what so ever what shall i do
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Jun 20, 2008
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898704
Points
3964
This is from memory
hold in the 1st and 3rd button and turn the knob to set the time.
press button which looks like a small steaming pot and it should burst into life
Smeg SD012 top oven failed
Is the clock set to auto and not manual? Is the clock display flashing? If so then set to manual, this should do the trick
Jan 17, 2014 • Smeg Ovens
Dont know how to turn off the auto seting
Turn off the mains power. wait about thirty secs. turn back on, you should have either all 0's or 8's flashing. Looking at the clock buttons left to right. press the button fourth from left and the - or + to set the time (doesn't have to be the correct time, just not flashing 0 or 8's). Leave for second until the display is not flashing.You should be able to use the oven now. If not you may have a problem with the clock, this can happen if you have been using the top grill with the door open and the controls have gotten too hot. Neff ovens have no function where the door is left open during cooking or grilling.
Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
6helpful
2answers
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
I have a very old tricity double oven with a top part and bottom part of the oven it doesnt have a hob as thats separate.It has three nobs to the left that are for the grill, the lower oven and the main...
I think I might have a manual for this oven! Is it a built-in job with the grill at the bottom and main oven at the top, made by Thorn Tricity?
Aug 07, 2009 • Ovens
24helpful
2answers
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
2helpful
2answers
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 • Ovens
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
