Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv KV25X5U
Channel changes at random every 2 to 3 seconds
  • markinho May 07, 2008
    sony KV25X5U tv changes channels randomly every 2 or 3 seconds
  • chrisy67 May 07, 2008
    my television does the same thing it goes from one channel to another and back.
  • 71 Answers
Have to replace the push switches behind the front buttons for channel change, chassis has to come out to repair
Posted on May 10, 2008
6ya staff
SOURCE:
My LG LCD TV cant stop changing channels on it own . I ve removed the batteries from the remote but still its changing them on its own
Is it going one way - channel 1-2-3-4-5 bottom to up or any way at random. Find out which way and check the channel button on the TV to see if it is stuck.
Mar 17, 2011 | LG 37LD450 37 in. TV
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sony Wega 27in Randomly Has Block Box Appear On Screen
this means the TV having picture upper part of the screen. problem may be -15 V to vertical deflection ic suddenly gose off and system control gose to stand-by mode resolder vertical out ic , -15 v supply line from the fly back and system control .
Jan 15, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
SONY KV-25X5U, TURNS IT'S SELF OFF AND STAND -BY LIGHT FLASH'S?
The standby light should be flashing in a repeated count with a short pause between the counts. If you could post that count here, it will give us an indication of the circuit in which a problem was found and allow us to provide solutions.
Thanks,
Dan
Oct 10, 2008 | Televison & Video
Channel changing randomly
the channel switch button had a contact to each other... or clean it...
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Channel changes automatically
There are a few things that can cause this. #1 most often cause is either something spilled on the channel button or something wrong with the bezel where the buttons are located causing the button to be pressed all the time. Check the buttons on the tv and make sure none of them are stuck. #2 is a bad button (switch). Replace the switch or the control board. #3 is a short on the wiring harness going from the switch to the mian board. Maybe it's squished against the frame somewhere. #4 would be a bad main board. You will likely have to take this unit to a service centre to have it looked at.
Apr 14, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
