Expert
- Posted on May 05, 2011
Re: Mower deck clutch cable removal (model 917.28722). ...
You should not need to remove the deck or the clutch cable just to change the belt.
- ensure mower clutch lever is in the off position
- lift the front of the tractor approx 24 or more inches.
- lower the mower deck as far as it will go
- locate & remove the cotter pin from the right (discharge) side mower lift arm where it attaches to the rear of the mower
- release the lift arm from the mower deck to allow it to drop (it will hang from the other 3 points)
You should now have plenty of clearance to change the belt. Remove the belt from the engine pulley first and replace the new belt on the engine pulley last that will make it easier to change the belt.
If this is helpful please vote yes, Thank You!!
