Loopback detection is used to prevent any looping of signals of on two ports it will shut the 2 ports down until line is cleared perventing a collision of packet jam Notifies administrator where a problem is
<SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 12pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">Ping the loopback address of the host having a problem. This will verify that TCP/IP is installed and configured properly on the computer.<BR><I>ping 127.0.0.1 or ping loopback</I></SPAN>
Subject:Supplemental Inflatable Restraint (SIR) Light ON, Diagnostic Trouble Codes (DTC) B0013, B0014, B0017, B0043, (Inspect and/or Replace IP Harness to Inflatable Restraint Module (Air Bag) Yellow 4-Way Connector C221 and/or C222)
Models:Tahoe
• The SDM detects the air bag module deployment loop resistance is greater than 4.8 ohms for 500 milliseconds.
• The SDM detects that the voltage at the air bag module high control is less than 2.4 volts and deployment loop resistance is 6 ohms or greater for 500 milliseconds.
In Management section, you can Backup/Restore Setting, Firmware Upgrade and Reboot the system in following pages.
If you act the function, the ip address will restore the establishing value situation.
192.168.1.20 in the IP Address field and 255.255.255.0 in the Subnet Mask field.
Hope this helps!
