Sounds scary! How steep is the hill?
Could you jack up the back end of the mower and check both wheels are driving? Maybe get it running slowly and get someone to carefully try and stop each wheel from turning with some sort of friction, eg a broom. If just the left wheel is driving you could get similar symptoms to what you describe. Some mowers have a key in the axle to wheel joint - if this is the problem then maybe yours is shorn.
Sounds like your drive belt is slipping alright. Need to tighten your clutch rod. One end of rod adjust. Have someone help you, move the clutch petal and your helper watch and see rod moves.
Hi, it sounds like the hydrostatic drive is getting too hot. Remove the battery and battery cradle and clean all grass and debris from around the hydrostatic drive and cooling fins. Also check the fan wheel on the hydro is not damaged. Regards Phil.
