That presser foot with that black thing that is just flopping around... well when the presser foot is down that thing should be locked into the side hole. when you have the presser foot up, put it into the side hole, fiddle with it, move it around til you find that hole, then drop the presser foot it should be locked on it now. That T presser foot needs that.
Thanks for the tip. However, I've tried to do that and it still failed. The little black thing on the side has a spring on it and it seems like it should fit snuggly into the hole. However, it only does so if I push and hold it in.
Also, I've tried other feet on the machine and I still can't get the machine to sew. I really hate to have to take it in to a sewing machine repair shop if it's a simple fix.
Thanks.
that same presser foot with that spring, i put it into my hole and it stayed! i lowered my presser foot and it seems locked in nicely. i know and you know that there is no sensor to tell if you have that in or not. how strange. listen don't be afraid to lug it to a shop. that is where mine is at right now. nothing wrong with it, i just am the kind of person that once a year i get a tune up if i really love my machine, it gets serviced. $65.00 for a comptuer machine. so that part sucks. im stumped with you. bobbin winder is in off position right. feed dogs are up right? power on slowly rotate wheel towards you with presser foot up, then click it down, see if that works, press mode, see if that works, otherwise you are going to the shop! its beyond me and you.
Thread your machine with the presser
foot UP. The disks that control the tension (thread goes through
them) are tightened up if the foot is down.
Change the machine tension with the
presser foot DOWN. Because the disks won't be engaged (see above)
if the foot is up, the disks won't move.
Start at the middle setting, 3. Go up
to tighten, decrease to loosen. Each machine is different, even 2
different machines of the same model. The best thing to do is start
at 3 and use a different color in the top and bobbin thread so you
can easily see what changes to the tension do to your stitches.
Now use a straight stitch a sew 3 or so
inches. Take a look at the top and bottom of the fabric. You don't
want to see any (or at least not much) of the other color showing
from the other side.
Loops on the bottom of the fabric means
you need to tighten (increase) your top tension. If you're stitches
on the bottom are causing puckering, then you need to loosen you're
top tension. For the most part, you really don't want to touch your
bobbin tension-leave that to a repair technician. The factory setting
shouldn't be touched except by someone who really knows what
they're doing.
Keep sewing a few inches at a time until you have the results you want. Now you're tension is where you need it!
they're doing.
you need it!
