You can find replacement batteries on amazon, click here and take a look: Amazon com Black and Decker 24 0 Volt Lawn Mower Battery 90508011. I hope this was helpful. Cheers
I have the CMM 1000 and recently bought new batteries. I don't know if the CMM 1200 uses the same batteries, but if not you can probably find them where I got mine. I looked at a lot of places online, and Battery Solutions, Inc. had a really good price.
www.batterysolutionsinc.com
UB12180 12 volt / 18.00
Amp Hour
Part#:
UB12180
Manufacturer Part#:
UB12180
(Qty: 2 x
$29.95)
Shipping was about $15.00.
I recommend not buying a aftermarket battery because usually they are not the same quality. You can buy a brand new orginal black & decker battery on this site:
http://www.acehardwareoutlet.com/productdetails.aspx?sku=296040001
or go to www.acehardwareoutlet.com and type in ace # 296040001 in their search engine.
This model will fit CMM1000 and CMM1200 19" Cordless Rechargeable Mulching Mower. 24 Volt
SOURCE: how do I remove the
I have an older model CMM625, but I suspect that the method is similar. There should be some screws that hold down the upper deck to the lower one. On mine the screws are in the back and there are tabs in the front that holds the upper deck to the lower. Once this is removed, you can see the battery and it's connections and hold down bracketry.
SOURCE: replacement grass catch bag for
It appears that you will need to contact the service center as in your parts diagram, the bag is not listed. A mulching blade is listed, which doesn't require the use of a bag.
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=MM600&selectedType=4882
Mower will not hold charge. Need new batteries. Ace Hardware has Mfg# 905080-11 in stock.
how does ne replace the battery. I have had a cmm1000 for 10 years and this is the first time i have to replace battery
